I just downloaded DVDStripper and when i try to install the software it gives me an error saying
"Component 'COMDLG32.OCX' or one of its dependeccies not correctly registered: a file is missign or invalid"
What should I do..?
Hi, you need to install some files
http://www.dvdrbase.com/showthread.php?p=192745#post192745
that should hopefully get you started and you may also find titlesetblanker and vobblanker useful
will not install
By ka3wjz in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 30th Jun 2009, 21:07 -
Uninstall/Install over or Install new versions separately?
By MindF in forum ComputerReplies: 2Last Post: 5th Apr 2008, 13:43 -
I Cant install IE7!
By GangstaRap in forum ComputerReplies: 2Last Post: 16th Sep 2007, 09:03 -
Use without an install
By raschko in forum Newbie / General discussionsReplies: 0Last Post: 9th Aug 2007, 16:37 -
install
By Brasilman in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 29th May 2007, 09:17
