Using MainConcept Mpeg Encoder to convert .avi to Mpeg2 and the resulting file is upside down.
How do I fix it?
https://www.videohelp.com/forum/viewtopic.php?t=150504
Please try a forum search next time - it will save you waiting for an answer, as well as someone else having to find it for you! -
Originally Posted by Cobra
OK that topic didn't really address my issue.
Couple things:
1. If I uninstall my codecs I won't be able to play my files.
2. This only happened with ONE FILE using Mpeg Encoder.
I'd do the conversion with TMPGEnc but it keeps stopping halfway through.
All my other files convert fine with TMPGEnc or Mpeg Encoder and as a result I don't want to uninstall my codecs and screw things up across the board.
I just need to know if there is some kind of setting on Mpeg Enocder to keep the file from inverting. -
Use Virtual dub filter to flip your video right side up, then use VFAPI to make a pseudo AVI file Main concept can use to encode the file to MPEG.
Hello. -
Originally Posted by SteyrAUG"Art is making something out of nothing and selling it." - Frank Zappa
upside down video in netmeeting
By ahidayat in forum Newbie / General discussionsReplies: 4Last Post: 29th Jan 2020, 03:41 -
Video thumbnails are upside down
By thegeeman in forum Newbie / General discussionsReplies: 2Last Post: 30th Mar 2011, 05:36 -
Video is upside down in DVD Workshop 2
By darkcyber in forum Authoring (DVD)Replies: 12Last Post: 7th Oct 2007, 21:22 -
My video is upside down
By Baldrick in forum Newbie / General discussionsReplies: 42Last Post: 7th Oct 2007, 10:02 -
divx 6.6.1 is killing me. upside down video
By yandao87 in forum Newbie / General discussionsReplies: 4Last Post: 5th Aug 2007, 11:33
