Results 1 to 10 of 10
  1. Can someone send me a link to download this tool?
    Thanks, Rocco
  2. Thanks for the link , and I apoligize for what may be a silly question, but is DTOX the same as DVD2OneX?
    If yes, then I already have that program and it is the one that keeps crashing on me.
    If No, I was looking for DTOX as a means to correct whatever is causing the DVD2One to crash.
    That is what was suggested to me by another person on the DVD2One board.
    Does this make sense to you?
    Thanks in advance for the help.
    ACR
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    D = DVD
    T = To
    O = One
    X = OSX version
    crashing? when does this happen, the app is very solid and has yet to crash on me. what exactly did this person on the dvd2one board say?
  4. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    It might be a bad DVD. Does it crash on all DVDs or just one or 2? Also, you can try trashing its preferences file, and maybe disabling APE (or the hacks that use it) if you use that.
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
  5. Hi Guys,
    Here is a copy of my posts. I should have come to you guys first, brain cramp on my part. Must have been Red Sox Fever. Anyway here goes and thanks in advance.
    Hi Guys,
    I am having the same issue with quitting in conversion after MTR ing a DVD.
    Can anyone make sense of any of this error message? Something happened on 'thread 3.'
    Thanks in advance.
    Immarocco
    Date/Time: 2004-10-21 06:40:26 -0400
    OS Version: 10.3.5 (Build 7M34)
    Report Version: 2
    Command: DVD2oneX
    Path: /DVD2oneX.app/Contents/MacOS/DVD2oneX
    Version: DVD2oneX version 1.4.1 (1.4.1)
    PID: 68
    Thread: 3
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000000
    Thread 3 Crashed:
    0 DVD2oneX 0x00023c84 ReadMacroBlock + 0x68
    1 DVD2oneX 0x00023c70 ReadMacroBlock + 0x54
    2 DVD2oneX 0x000199d0 ProcessStream + 0x614
    3 DVD2oneX 0x0001e7a4 MainProcessGOP + 0xe8
    4 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28
    Thread 4:
    0 libSystem.B.dylib 0x90016f48 semaphore_wait_signal_trap + 0x8
    1 libSystem.B.dylib 0x9000e790 _pthread_cond_wait + 0x270
    2 com.apple.Foundation 0x90a4bb00 -[NSConditionLock lockWhenCondition:] + 0x44
    3 com.apple.AppKit 0x92f5f9b0 -[NSApplication _doModalLoopeek:] + 0x114
    4 com.apple.AppKit 0x92f5aef4 -[NSApplication runModalForWindow:] + 0xb0
    5 com.apple.AppKit 0x92fe7a5c _NXDoLocalRunAlertPanel + 0x2c4
    6 com.apple.AppKit 0x92fe7538 NSRunAlertPanel + 0x40
    7 DVD2oneX 0x00011328 -[DVD2one startAlertPanelTask:worker:] + 0xa4
    8 DVD2oneX 0x000144e8 -[ThreadWorker runPrimaryTask:] + 0x58
    9 com.apple.Foundation 0x909f30e4 __NSFireTimer + 0x68
    10 com.apple.CoreFoundation 0x901946a8 __CFRunLoopDoTimer + 0xf4
    11 com.apple.CoreFoundation 0x90191a08 __CFRunLoopRun + 0x5c8
    12 com.apple.CoreFoundation 0x90195f1c CFRunLoopRunSpecific + 0x148
    13 com.apple.Foundation 0x909fc850 -[NSRunLoop runMode:beforeDate:] + 0xac
    14 DVD2oneX 0x00014440 -[ThreadWorker startThread:] + 0x154
    15 com.apple.Foundation 0x90a39b74 forkThreadForFunction + 0x6c
    16 libSystem.B.dylib 0x900246e8 _pthread_body + 0x28
    PPC Thread State:
    srr0: 0x00023c84 srr1: 0x0200f030 vrsave: 0x00000000
    cr: 0x28828422 xer: 0x00000000 lr: 0x00023c70 ctr: 0x00000000
    r0: 0x00000200 r1: 0xf00e0c10 r2: 0x00030000 r3: 0x001730dc
    r4: 0x00000004 r5: 0x00023c70 r6: 0x00030000 r7: 0x0006e824
    r8: 0x001e0e5c r9: 0x00000000 r10: 0x00000000 r11: 0x98a08000
    r12: 0x001e0e5c r13: 0x0006e828 r14: 0x00030000 r15: 0x01ecd804
    r16: 0x01ed3672 r17: 0x00030000 r18: 0x00000013 r19: 0x00000114
    r20: 0x00070000 r21: 0x00000000 r22: 0x001730dc r23: 0x00178fac
    r24: 0x000001ee r25: 0x000001e8 r26: 0x001730dc r27: 0x00178f78
    r28: 0x00030000 r29: 0x00034804 r30: 0x000347e8 r31: 0x001730dc
    Thu Oct 21, 2004 12:34 pm*
    Immarocco
    Dear evdberg
    Hope you can help me.
    Any chance you might offer a solution?
    I recieved another copy of the disc I am trying to shrink and it too rips fine but crashes DVD2One.
    I did re-rip using DVD Backup and that file too also crashes DVD2One.
    The one thing I cannot figure out is.......
    When I insert the DVD I want to copy and do 'get info',
    it returns a file size of 8.52 GB. Which is very odd as the other 3 disc in this set have files that have been authored as single layer 4.3GB or smaller and others who have the same DVD get this message.
    The disc is only @4.3 GB but reads >8GB.
    >>Disc 4 shows these stats in DVD Decrypter:
    _NEC DVD+RW ND-2100AD 103D (ATA)
    Current Profile: DVD+R
    Disc Information:
    Status: Incomplete
    Erasable: No
    Sessions: 2
    Sectors: 2,258,864
    Time: 502:00:14 (MM:SS:FF)
    Physical Format Information (Last Recorded):
    Disc ID: CMC MAG-F01-00
    Book Type: DVD+R
    Part Version: 1
    Disc Size: 120mm
    Maximum Read Rate: Not Specified
    Number of Layers: 1
    Track Path: Parallel Track Path (PTP)
    Linear Density: 0.267 um/bit
    Track Density: 0.74 um/track
    First Physical Sector of Data Area: 196,608
    Last Physical Sector of Data Area: 2,491,711
    Last Physical Sector in Layer 0: 0
    By comparison, Disc 3 shows the following:
    Disc Information:
    Status: Incomplete
    Erasable: No
    Sessions: 2
    Sectors: 855,392
    Time: 190:07:17 (MM:SS:FF)
    Book Type: DVD+R
    Part Version: 1
    Disc Size: 120mm
    Number of Layers: 1
    Note that in both cases, Status is "incomplete," presumably because the discs were not closed/finalized in the burning process. When I load the discs I burned after ripping from Rick's, they appear as Status "complete."<<
    Hopefully you can help.
    Thanks Rocco
  6. Member WiseWeasel's Avatar
    Jan 2003
    So what size is the VIDEO_TS folder on that problem disc when you get info on it in the Finder? If it's already 4.3 GB, then DVD2OneX should be unnecessary. If it's over that, and you're getting these crashing problems, then it looks like an improperly mastered DVD. You can either try finding another copy of that movie, try using DVD2OneX in 'film' mode instead of disc copy mode, try using DVDRemaster instead, or as a last resort, try splitting the movie across two DVDs and remastering it manually with Sizzle or DVDStudioPro.
  7. Hey WW,
    Thanks for the info.
    The Video_TS folder says 8.3, though it clearly isn't as it was burnt on a SL DVD.
    There is no Audio_TS folder, instead there is the Audio_RM. Is this a problem?
    I have recieved the disc from 2 different persons now and in both instances those copies crash DTOX.
    I also tried copying w/o MTR but it crashed it too.
    It perplexes me.
    I will ask if one of my trading buds has a copy burned on a mac and see what happens.
    Thanks for the great ideas.
    ACR
  8. Have you tried a movie only copy? I seem to remember problems with AUDIO_RM (not part of DVD spec) folders and full disc copy.
  9. Hey PJ,
    I have not tried movie only. The disc has several different sources of video. 2 are concert performances from 2 different sources, 1 is a portion of a TV performance and another from a 4th source. I thought movie only would not work for different sources like this on DTOX.
    I may try it though.
    Thanks ACR
