  1. After I process the Mpegs in SVCD2DVD I use AVI codec to check frame aspect ratio etc.
    Most of the time they are 16:9 but sometimes 4:3. When I import Mpegs in external Authoring software namely DVD workshop, should I set it to what avi codec tells me. Ie 16:9 or 4:3 depending on what information is given?
    EG:Video : 0 Mb, 4996 Kbps, 25.0 fps, res. 720*576 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Sounds reasonable, if the DAR is correct in your mpegs...
    /Mats
