Is "Superman: The Movie" super encrypted? I can't seem to get it using DVD Decrypter or DVD43. Same with the new Star Wars IV DVD.
Results 1 to 11 of 11
I don't have the Superman DVD but it's probably encrypted and plenty of people have ripped SW IV
I dno't think SW IV has the 'new' protection on it but do you have the latest version of DVDDecrypter amyway and what is the exact error you are getting?
if you have the latest version of DVDDecrypter then it sounds like it could be 2 things. Either both the DVD's are faulty/scratched or your DVD drive is on the way out -
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
it ain't BS daamon, it's good suggestion 8). Play the DVD first then stop it and try ripping again
Cheers for the clarification MackemX - another little something to tuck away in my knowledge store...
Carpe diem.
Thanks for your responses.
I dont' recall the DVD Decrypter error but will try again. I'm using 3.5.1.0 which I believe is the latest vrsion.
I use DVD Shrink all the time and it had a problem with Superman.
I will try playing the disc and see if that helps. I recall an earlier piece of software that required that procedure before ripping and it worked. -
I tried playing the movie first then ripped it with DVD Decrypter and it worked.
Thanks to all for your help. -
The "play it first then rip it" thing DOES work, but it simply highlights what is likely a system misconfiguration.
That's just my take on it - I've never had to deal with it on any of my personal machines, but on machines that DID require that, after I redid them they no longer required that.
It could also be your burner, or motherboard, or a combination thereof.
I just did both movies and they work like a champ. I used DVDdecrypter and then used DVD2DVD-R.
How to create Superman titles
By prizi in forum EditingReplies: 35Last Post: 1st Jan 2013, 16:52 -
What's your favorite superman movie?
By johns0 in forum PollsReplies: 25Last Post: 11th Nov 2011, 15:37
