I am making a back up VHS tape from another VCR. How can I eminate an audio hum that I am hearing? I don't appear to have S Video, Component or Composite outputs.
I am using two older Mitsubishi (HS U520 & HS U577) decks.
Any advice would be appreciated.
Thanks,
E
Sounds like you have a ground loop problem.
1. Make sure both VCRs are connected to the same surge protector.
2. The humm might be coming from your cable system, especially if one is hooked up to cable and the other is not. Disconnect any cable connections.
3. Use hi-grade cables like Monster. -
Try plugging both vcr's into the same AC outlet, you may have a grounding problem.
"Art is making something out of nothing and selling it." - Frank Zappa -
try one of these, i had the same problem and it fixed it http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=270-054
If it's an ambulance...you got a chance. If it's a hearse...it's even worse!!!--Judge Alvin "JP" Valkenheiser
Want to extract audio from .vob files? Read my guide at https://www.videohelp.com/forum/viewtopic.php?t=187078 -
I finally got my recorder..and I love it (the Pioneer 420 from the Costco sale)...please advise where I best connect the ground loop isolator that I bought from Radio Shack. I got it today and want to try it...
vhs tape will NOT move through vhs recorder at all
By tepeco in forum RestorationReplies: 52Last Post: 24th Oct 2022, 13:31 -
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 10:32 -
Backup copy of Protected VHS tape
By mcassidy in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2009, 13:05 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 08:36
