I installed my pioneer 108 as master and set the cdrw/dvd rom combo as slave.. but why hasnt it changed letters? Shouldnt my dvd burner be E and the combo be F? Instead the dvd burner is F and the combo is E. What do I do? Or what if I leave my cdrw/dvd rom combo on cable select and set my dvd burner as slave? The dvd burner is on location 0 and the combo is on location 1. Or it shouldnt matter that the pioneer is set to slave? I heard that the drive doesnt like being slave, rather master? And does it matter with the drive having Ultra DMA Mode 2? Shouldnt it be 4? I burned a 4x in 13 min. 50 secs. 80 wire 40 pin, will I have purchase it then to burn at 16x ?
"What It Do"
Huh ????? -
the letter changing shouldn't matter. you burned a 4x disc at 13 min. 50 sec. which i think is ok if you're using 4x dvd media. if you want 16x speed burns you would need to use 8x dvd media that will be compatible on your 108 drive. verbatim has 16x dvd+r media at bestbuy. check out the pioneer forum at cdfreaks.com.
http://club.cdfreaks.com/forumdisplay.php?s=dc6f3a61d197c51d8098a52165f4b897&daysprune=-1&f=87 -
What about the Ultra DMA 2? Wont I need Ultra DMA 4 for 16x burning? I will need the 80 wire 40 pin? Im kind of new on this...Originally Posted by budz"What It Do"
Huh ????? -
I don't have a pioneer 108 drive. Ask your question in the Pioneer forum at cdfreaks.com. Using a 80 wire ide cable is better for dvd burners. As I stated if you want 16x burns you'll need to use 8x dvd media or 16x dvd media. The pioneer drive doesn't achieve true 16x speed throughout burning process. Check out the Pioneer forum for more information. There is a hack firmware for the drive at the forum.rpc1.org.What about the Ultra DMA 2? Wont I need Ultra DMA 4 for 16x burning? I will need the 80 wire 40 pin? Im kind of new on this...
http://forum.rpc1.org/viewtopic.php?t=28550 -
To change drive letters,right click [MY COMPUTER] click {MANAGE} to open the computer management console. In the top or lower right pane, right click the disk you want to change.Fixed drives appear in the top and bottom pane.Removable drives appear in the bottom pane unless they have media inserted in which case they appear in both upper and lower pane.Select [CHANGE DRIVE LETTER AND PATH] click [CHANGE] select the new letter from the drop down list box and click [OK]
Installed latest Ripbot264, says Java is not installed, even though it is
By fatcharlie in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 10:44 -
Having issues with dvd ripping and codecs - cant tell whats installed
By alex.ap.pacman in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2011, 01:40 -
The same OS installed on two disks
By Jomapil in forum ComputerReplies: 29Last Post: 4th Jun 2009, 16:35 -
Lost Cd to play dvdfilms after i have installed powere dvd cyberlink
By chikenkat in forum Authoring (DVD)Replies: 0Last Post: 12th Aug 2008, 19:36 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15
