Also cant seem to get response to this problem at various sites.
Anyway....try to erase DVD-RW disc by right-clicking on drive, selecting
"Erase this disc". Message appears that some app. is attempting to burn or write to the drive. Did get one suggestion that perhaps RecordNow was the culprit. I removed the program....same glitch.
Only app. that I found that had an "erase" function was ...RecordNow.
It also would not work....same message appears.
Any way to find what is locking onto the drive, and why would that prevent the erase function anyway?
use dvdinfopro
What We Do In Life, Echoes In Eternity.... -
Worked !! Thanks. Tried to view disc (as empty) and message popped up that the disc was unknown format (or ?). But had no problem on next burn,even though program I used generated another message...like disc is not empty, would you like to erase?. Chose yes, ...seconds later it was ready. Not sure about 2 message pop-ups, but no problems.
Ok good, glad I could help
I've found that DVD Movie Factory V3 sometimes does not like to erase my disk prior to a rewrite. I'll have to use another app like Sonic or Roxio to erase it.
Is it possible to erase a DVD+R?
By Han Solo1 in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2010, 13:54 -
How to erase a DVD-R disk
By bryankendall in forum ComputerReplies: 5Last Post: 24th Dec 2009, 13:16 -
DVD RW wno't erase
By jollyjohn in forum Newbie / General discussionsReplies: 5Last Post: 20th May 2009, 10:32 -
Can't erase my DVD-RW disc
By hurtstotalktoyou in forum DVD & Blu-ray WritersReplies: 4Last Post: 15th Nov 2007, 09:40 -
HELP - Can`t erase 10 dvd rw discs
By LOWTECH in forum DVD RippingReplies: 6Last Post: 13th Aug 2007, 14:28
