I'm using TMPGenc 3.0 and TMPGenc DVD author to make my discs. I've noticed a discrepency of what it reports the maximum capacity of a disc.
TMPGEnc says 4200MB is maximum. DVD Author has 4438MB as maximum. Do they just report it lower in the encoder, so you don't go over while adding menus in the authoring program? What is the correct capacity of 4.7GB DVD discs?
Strictly speaking, the capacity of a 4.7GB disc is 4,700,000,000 bytes, or 4700MB in base-10-derived "human speak" -- which equates to 4482MB in base-2-derived "computer speak".
It's odd that TMPGenc 3.0 would report the maximum as 4200MB, considering that 2.5 reports it as around 4400MB... maybe it's a bug, or maybe they are leaving a little head-room on the assumption that you'll be adding menus and such when you import the finished MPEG to a DVD project...
Burning to Full Capacity of a DVD
By Agent 5 in forum MediaReplies: 6Last Post: 16th Apr 2012, 10:49 -
Simple question on DVD+R DL discs/Capacity
By alegator in forum MediaReplies: 12Last Post: 19th May 2011, 05:52 -
New storage capacity
By GideonK in forum Latest Video NewsReplies: 30Last Post: 11th May 2009, 14:48 -
Exact maximum capacity of DVD+R
By geohei in forum Authoring (DVD)Replies: 18Last Post: 21st Mar 2009, 10:23 -
Roxio 8 misunderestimates DVD capacity? making lotsa coasters...
By ahhaa in forum ComputerReplies: 8Last Post: 7th Sep 2008, 19:57
