Been capturing from 8mm camcorder, after 20- 40 minutes , all of a sudden Capture stops, but audio continues to be captured. Video that is captured is OK. Have had success in past captures but this is fairly new problem. This happens with several brands of software. Here is info which may or may not be needed, I am desperate to get this job done soon![]()
My antivirus is off
Defragged
2.8ghz 512 ram, 120gb hd
Avermedia pci card
MPEG-2
Video mode 29.97fps
Aspect ratio4:3, Frame size 720-480pixels
Virtual Memory: Inital size-768mb
Max size- 1536mb
THANKS FOR ANY HELP!!!!!!!!!
[/b]
Here's a few random suggestions:
Have you tried going back and re-capturing a tape you know you've been able to capture properly in the past? Maybe there are some glitches on the tape you're currently trying to capture that're giving the Avermedia card trouble.
Have you cleaned the heads in your camcorder recently?
Are you running any other processes while the capture is in progress? (And if you've installed any new software recently, are you sure that you're [/i]not[/i] running something new in the background that you don't know about?
MediaPlayer Classic fails to capture snapshots
By terrypin in forum Newbie / General discussionsReplies: 4Last Post: 7th Mar 2009, 11:04 -
mencoder fails
By scruss1 in forum Video ConversionReplies: 1Last Post: 11th Jan 2009, 23:48 -
burns fails. help
By dymx in forum Newbie / General discussionsReplies: 8Last Post: 18th Jun 2008, 14:54 -
Burning always fails at 98%...
By Variable in forum DVD & Blu-ray WritersReplies: 14Last Post: 29th Feb 2008, 16:45 -
Only recorded 30 minutes on a 60 minute tape, can't capture
By kyroha in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 11th Jun 2007, 10:40
