when i try to move the assets etc bin files to the tileset layout they will not go in there,any help please
only *.avi or *.mpg files can be dropped on the titlet set layout. From the help:
From the release notes:
If you are processing BIN files: Load them as assets and do a batch extraction (Process Assets->Extract…..). Then start a New project & load the mpgs. This is to allow you to check the mpgs for sync issues.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Layout of mediainfo
By pooksahib in forum Newbie / General discussionsReplies: 4Last Post: 27th Feb 2012, 09:30 -
DVD with .layout and .LAY files
By Case in forum MacReplies: 1Last Post: 9th Sep 2010, 03:00 -
bin files
By fredreed in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Nov 2009, 01:02 -
I require assistance with a layout, please.
By Zynn in forum Authoring (DVD)Replies: 3Last Post: 5th Feb 2008, 08:39 -
Encore Layout Help- Im getting embarresed
By RealitySets in forum Authoring (DVD)Replies: 1Last Post: 12th Sep 2007, 02:12
