I have a movie which is 8 gigs, if i use dvd shrink to make it fit on a 4.7 disc, will the quailty loss be noticable at all?
It may be noticable, but if you're not in a rush, use deep analysis and select either sharpest video or smoothest video in the options field, this should give you the best results. It may take close to 45 minutes, but may be the route to take.
Depends on what system you view the backup. "Tube" TVs will be much more forgiving, while DLPs, Plasmas, Projection TVs, & Projector systems will be much more discriminating.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
Your setup is close to mine, so it will take closer to an hour and a half to complete the job. You can change the compression ratio for the extras and menu, and eliminte non-essential languages to increase the room available for the main movie.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
