Starting with v 2.6 DvdReMake Pro can be used to merge 2 full dvds.![]()
Procedure is completely automated, you simply import disks you would like to merge, go to "Tools\Merge DVD..." menu and select projects to be merged. As a result you will get a new project with a start up menu asking what disk you would like to go to. After that selected disk will play as if it is the only one on the DVD.
At any time during playback pushing "title menu" on the remote will take you to this start up menu.
http://www.dimadsoft.com - home of DvdReMake and MenuEdit tools
Do you have any guide?...even if it is very simple it is even simplier with screeeenshots and I can also add it to the guide list so more can find it.
Now I do
I've submited it via standart "submit guide".
Editing a MTS Files and keeping the original quality?
By PHNeedsHelp in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 19th Feb 2011, 12:38 -
burn multiple dvds with original menus
By pins123 in forum DVD RippingReplies: 1Last Post: 26th May 2010, 16:31 -
Adding .srt to a DVD and keeping the original subs
By Levina in forum ffmpegX general discussionReplies: 9Last Post: 23rd Apr 2008, 17:20 -
ripping dvds and keeping menus
By eusthebest in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jan 2008, 21:02 -
Removing scenes from DVD while keeping original Menu?
By saini in forum Newbie / General discussionsReplies: 1Last Post: 25th Oct 2007, 22:42
