New beta, beta 4:
https://www.videohelp.com/forum/viewtopic.php?p=1086163#1086163
In this version I am introducing PAL to NTSC conversion. A lot of people have asked for this so here it is!
At the moment it only works for MPEG-2 (svcd etc) mpegs, not avi or vcd. I will introduce those soon. It is experimental, due to the fact that i have not had chance to test it on many mpegs. Those i have tested work ok. Obviously the mpegs need to be re-encoded to perform the conversion so the processing time is significantly longer - if your player plays PAL then don't choose this option!
Let me know if it does the job.
CB
Results 1 to 1 of 1
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19 -
capturing PAL Beta tape
By sickyd in forum Capturing and VCRReplies: 5Last Post: 1st Aug 2007, 23:14
