but anyways.. Search, i've looked here is whut I want to do
I have 2 movies..
they are 4 differ files (each movie cut into 2)
I Wanna put them onto a dvd-r .. they are divx right now, whuts the easiest way to do it? i need to have it done by t/m.. Thx!!1
(can i just burn them as a video cd to dvd-r? or whut
Results 1 to 14 of 14
only_emo_kidGuest
a vcd and a divx file are completely different ...
non the less -- encode to DVD standard mpeg2 , encode the audio to ac3 , author with a authoring app , burn to dvd
see guides off to the left ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
no - oh god no ...
make the divx a dvd"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
only_emo_kidGuest
alright, lmao.. i was following http://www.dvd-guides.com/content/view/70/59/ and i loaded the movie, but it didn't have ac3 it had mp3 audio.... wtf? and then loaded the .avi into tmpg and it doesn't show mpeg2? also.. it wants to make the movie the size of like a dvd-r and i wanna put like 2 or 3 movies on a dvd-r is that possible?
possable yes
could just buy the movie(s) :
to adjust the size of the file -- change the bitrate ...
see the guides ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
only_emo_kidGuest
alright, well i need these for halloween t/m to watch with g/f
(they're not availble around here)
well the easiest way is to buy a dvd player that can play divx/xvid files (and there are many that can do this)
did you see this guide on the front page btw ?
https://www.videohelp.com/guides.php?guideid=697#697"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
only_emo_kidGuest
yeah i made that link in one of my posts... whut i've done right now to see how it works out is... add the files to VCD on nero, and put in a dvd-r and then go to burn, and nero is encoding the files.. i'ma see how that works
not to well - as nero encoder is not that great
New LG DVD Player not playing VCDs
By atlmallu in forum DVD & Blu-ray PlayersReplies: 15Last Post: 4th Dec 2010, 16:28 -
VHS tape won't rewind in mulitple players
By robjv1 in forum RestorationReplies: 15Last Post: 19th Aug 2009, 18:18 -
DVD units playing VCDs in black and white only.
By electric green in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2008, 13:37 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 03:52 -
Editing to match tapes from mulitple cameras of the same event
By SCDVD in forum EditingReplies: 5Last Post: 17th Mar 2008, 19:06
