I have a divx file and I want to be able to play it thru my DVD player. The player does not play avi files. The file is 820MB and will not fit on a CD. What's the best way and how to fit this file on a DVD? Can I burn it as a VCD on a DVD? Is it possible to covert divx avi to MPEG-2?
thanks,
webtekie
	Hello,
 Here's a list of guides on how to do divx to dvd:
 https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=DivX+to+DVD&...or+List+Guides
 If they're vcd then look here and select vcd to dvd:
 https://www.videohelp.com/convert
 These guides are on the left of the screen under "How to". Good luck
 KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	www.thefilmmachine.com has an easy to use conversion tool.
 You can get a VCD-DVD onto a DVD. All you have to do is patch it and change the audio to 48mhz. As the previous poster mentioned, to a search (or look in the guides sections drop down VCD-DVD or AVI to DVD)
	thanks guys.
 About those conversion tools...I try couple of them and every time I open my avi file the program stops responding. No errors...just dies. What's the problme?
 thanks,
 webtekie
	The AVI.
 /Mats
	Quality is subjective.
 Do what works for you and quit asking what is the best way.
 It would also help if you read the guides before asking questions.
  Copy divx into DVD and then runBy gozuhair in forum Newbie / General discussionsReplies: 4Last Post: 26th Oct 2010, 06:48
  Is copy Sony PSP game same as copy DVD disc?By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26
  How can I copy a copy-protected DVD and have only ONE VOB fileBy Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 01:31
  Unable to copy copy-protected data DVDBy J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 12:23
  LG lh-rh361se: How to copy divx to DVD?By picchew in forum DVD & Blu-ray RecordersReplies: 3Last Post: 9th May 2007, 07:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
