Hi All
I know this more than likely been asked a thousand times, but I have looked through the forum and cannot find what I seek.
Can anybody point me in the direction of a written crib sheet on converting an MPEG to burn onto a DVD with a front screen etc ?
Thanks for your time.
I use an eMac and have iMovie, Toast 6...
Washac
I don't know if this has any Mac stuff, and I apologize if it doesn't but the first place to start is:
not under there, but there are some under this sticky as well as my website
keep in mind that mpeg to dvd is the same as VCD/SVCD to dvd -
Hi All
Many many thanks for the replies so far, but can I word my problem another way maybe.
I have 2 Mpeg files and wish to create a DVD with them which also incorporates a front title screen with a play button and maybe some chapter selecting buttons.
Programs I need and a walkthrough on how to this would be great
Or can this all be done with Toast 6?
Washac -
it can be done with toast, but it can also be done using my tutorial and Sizzle
check out the SVCD to DVD tutorial, since that also does mpeg to DVD
you can use 2 or 20 just line them up
want to capture directly to ffdshow mpeg-1 or mpeg-2 for dvd
By wolfdogg in forum Capturing and VCRReplies: 10Last Post: 10th Jan 2012, 08:23 -
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 09:52 -
MPEG II to MPEG (DVD): Transcode or reencode?
By Jeroen1000 in forum Video ConversionReplies: 8Last Post: 12th Feb 2009, 18:44 -
MPEG-1 to MPEG-2 to DVD Advantages/Disadvantages?
By louv68 in forum Video ConversionReplies: 4Last Post: 7th Jul 2007, 17:51
