I would like to ask you if someone have experience with re-recording movies played in DivX player. I tried four or five tools, but it's recorded just black screen. Is it possible to record DivX movies (played in DivX player) to another format (means real-time re-recording)? (really need re-recording, conversion is not possible). Thanks for answer.
Regards
Michal
Why is it not possible to convert the original file? What makes it so special?
If you look for an option that says to display the video as an overlay, and disable it then it should get rid of the black screen problem (I think). Worth a shot, anyway.
Cobra -
Well the DIVX file looks to be encrypted. It is not possible to play it without internet connection. So than I need to re-record it. Can you recommend me some software for re-recording? I tried e.g. ACA Capture (http://www.acasystems.com/) but it records just black screen
Question about VHS recording
By gejlvem in forum Capturing and VCRReplies: 1Last Post: 12th Jan 2011, 18:24 -
Recording/Conversion Question
By hobbesent in forum Newbie / General discussionsReplies: 20Last Post: 16th Dec 2010, 16:32 -
Video Stream Recording Question (Looking for answers)
By likwid8 in forum Video Streaming DownloadingReplies: 2Last Post: 2nd Oct 2009, 11:58 -
DVD Recorder, TV Recording, and Interlace Question
By CobraPilot in forum Authoring (DVD)Replies: 9Last Post: 20th May 2008, 20:53 -
Question about Recording software
By Me-Hostage in forum Capturing and VCRReplies: 2Last Post: 29th Jun 2007, 23:34
