I have been using a technique mentioned here for final touch size reduction of DVDs. Some authored DVDs annoyingly grow slightly beyond the 4.36Gb mark. I have tried using DVD2One and DVDShrink to make a 2~3% size reduction to make them fit on a DVD.
I notice that DVDShrink is useless in this respect. Quantization noise becomes apparent and pictures appear to be composed of single color macroblocks when motion is high.
DVD2One gives much better results.
This - of course - is also a matter of source material. I typically use this for DVDs of captured TV episodes encoded at 3400kbps at full PAL resolution. I know the bitrate is low by itself, however the MPEG video files look fine and the authored disk is 99% TV quality - before shrinked.
Just to let people know that DVD2One may be a better tool for such cases than DVDShrink.
The more I learn, the more I come to realize how little it is I know.
Correct. However, if you want to combine 3 or 4 films (e.g. episodes), plus some motion menus, plus subtitles, you may end up with a few Mb overshoot in total size.
Re-encoding a 45 min episode doing a 4 (1+3) pass with CCE on a P4/2.8 takes about 2.5 hours. And then, the original video must be removed from the authoring script, chapters must be reset, links must be re-established and a lot of other mundane things must be redone.
Taking the authored DVD through DVD2One or DVDShrink, only takes 15 minutes or so.
I believe that shortcuts are good. If they take you to where you want to go and the road is not roughThe more I learn, the more I come to realize how little it is I know.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
audio out of sync / file size reduction
By rancid in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jan 2009, 07:55 -
Is the Ipod touch 2G the same size as the Iphone?
By ryangarfield in forum Portable VideoReplies: 0Last Post: 28th Oct 2008, 00:20 -
DVD Rip Final Size Differs
By brvignesh in forum DVD RippingReplies: 7Last Post: 10th May 2008, 11:40 -
Photo image size for iPoid touch
By BeachNut in forum Portable VideoReplies: 0Last Post: 3rd Nov 2007, 07:39
