Hello
How is it possible to make a dvd-ripped movie of 2 hours to fit in a 700megs cd and still get really good quality.
I got "the mexican" a movie of 2 hours(downloaded from the net) and it's really great quality and "only" 700megs.
In all my attempts to make a divx copy from a dvd using Smartripper and then either flaskmpeg or dvd2avi i find it impossible to get that good quality in 1cd.
Is there any other methods that is more "proffesional" and not awalibile for the common people when you're making divx movies. Or how does this guys manage it?
/Mr Walker
Results 1 to 10 of 10
yup convert it to a divx movie file and you can put it on a single cd but you cant play it on DVD Players or VCD players
You may be able to if you use Nandub with GuardianKnot, the guides are at http://www.doom9.org Your pushing it though.
Thanx for the reply pinoy2201, but I don't really see an answer to the question.
<font size=-1>[ This Message was edited by: Mr Walker on 2001-11-27 15:01:34 ]</font> -
It is possible the 700Mb 'quality' movies of which you speak were encoded with a 2pass VBR.
Under 'properties/details' what is the codec used? -
properties looks like this (in swedish):
LJUD:
ljudformat mpeg layer-3
medelhastighet 15.999 kb/sek
samplingsfrekvens 44.100 kHz
kanaler 2(Stereo)
VIDEO:
Namn The mexican-divx.avi video#1
bild bredd 640 bildpunkter
bild höjd 272 bildpunkter
speltid 7400.942 sekunder
antal bildrutor 177445
bildrutefrekvens 23.976 bildrutor per sekund
datahastighet 97.43 kb/sekund
videosampel 24 bitar
videokomprision DIVXMPG4 V3
/Mr Walker -
The 2-pass vbr helps the quality and also notice the resolution 640x272. Cropping off the black bars from the letterboxing and also slightly reducing the resolution from 720x480 makes the most of the low bitrate.
Just to jump in.
Surely you're not talking, actually playing those in a standalone dvd player?
640x272 don't sound like VCD or xVCD, let alone, play in any stand alone dvd
player. In fact, I would go as far as saying that these are NOT VCDs in any
way, ...as vcd's are for playing in dvd players.
And, as a test, I made a quick encode with these settings 640x272, and both
my Apex dvd players did not play them!
Go figure!
<font size=-1>[ This Message was edited by: vhelp on 2001-11-27 17:52:12 ]</font> -
I'm sorry if my first post wasn't all clear, but we're talking divx all the way on this one. Never intended to use a standalone here.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
This is the method used, it's similar to two pass MPEG2, but using DivX. It can give amazing results. But it is complicated.
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 12:07 -
Whats the diffrence between AC3 Blu-ray movie and a x264 movie?
By evdeneale in forum Newbie / General discussionsReplies: 1Last Post: 20th May 2011, 23:16 -
Windows Movie Maker crashes and won't puplish whole movie
By LoveMyslf in forum Video ConversionReplies: 27Last Post: 12th Dec 2009, 22:19 -
Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!
By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 11:33 -
kvcd - 2hour 1 disc
By t41 in forum Authoring (VCD/SVCD)Replies: 27Last Post: 18th Sep 2007, 06:09
