I'm pretty savvy with conversions, so I wouldn't be posting about it if I wasn't really having a problem. Here's the lowdown...
I'm doing a PAL to NTSC conversion of a live concert. Done it a million times before. I've got my video finished and have converted the audio. I checked them both out, and they're perfectly in sync. Cool. Unfortunately, when doing PAL>NTSC conversions for music-based stuff, the pitch slowdown is quite noticeable, so I use an audio program to raise the pitch while keeping the same time-length. Here's where it get's weird. Once I do that, the final output file reads to be the same size and the same length, according to all my programs. But when I do my final multiplexing, the resulting video is wayyy out of sync with the audio. I don't understand it, as it's the exact same length as the un-pitch-corrected audio file (which synced perfectly with the video).
I've done this tons of times with conversions, all successfully. This is the only time I've seen this problem, and even tried using three different audio programs to do the pitch correction. All were out of sync. I'm pretty stumped here, so any help would be appreciated.
You talkin' to me?
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
convert audio from PAL to NTSC
By Ankin in forum Newbie / General discussionsReplies: 18Last Post: 15th Aug 2009, 16:13 -
Converting PAL to NTSC and rip PAL Audio to WAV in VLC
By happydog500 in forum Video ConversionReplies: 1Last Post: 8th Aug 2009, 01:47 -
PAL to NTSC - keep audio pitch
By sambat in forum Video ConversionReplies: 6Last Post: 31st Oct 2008, 23:14 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
