Hi All,
I've been playing around with Vdub and xvid - unfortunately without much success.
I've captured video from VHS ntsc recordings ( using my dv camcorder as the junction between VHS player and PC ), the res is 720 x 480. I'd like to produce a vid that is rougly 600megs. All my efforts to resize and encode the capture to Xvid result in files sizing from 1.2g up to 5g. Obviously I'm doing something wrong, at this point I'm thinking it's because the captured video is at 720x480. Now my question - can I resize the capture and make a 1hr 45min vid clip under 700megs.
Or do I need to recapture at something less - say 640x480 or 352x288?
I used WinDV to capture to .avi - then opened said .avi in Vdub selected null transform, deinterlace, and resize filters (352x?). Selected compression->xvid and tried all sorts of different settings from xvid guides I've found.
At this point, i'm not concerned with DVD compliant file- just need a small fize size.
TIA
Joachim2311
You didn't mention bitrate in your post, but I'm assuming you've calcutated the bitrate to fit your video into 700MB right?
https://www.videohelp.com/calc.htm/
Otherwise, what kind of audio compression are you using? I ask because if it's captured video you could well have uncompressed PCM (wav) audio which could well take up more space than the video. Best to use mp3 audio, download the Lame ACM encoder if you don't have it, it's in the tools section. 128kbits/sec is a good standard, but don't forget to factor it in when you calculate your video bitrate.
Also, consider splitting your file in two (accross 2 CDs worth). Compression like Xvid depends on large portions of the image staying the same, and analogue sources like VHS are so wobbly that nothing really does stay the same. So, if you're forced to use a low bitrate the quality could be quite rubbish - but then I guess with VHS it never was brilliant to begin with...
What does anyone want, but to be a little more free?
Captured video huge in size
By Zooropean in forum Newbie / General discussionsReplies: 4Last Post: 25th Mar 2011, 16:55 -
Captured video but what to do since file is huge.
By I26 in forum Newbie / General discussionsReplies: 3Last Post: 30th Dec 2010, 20:19 -
Good bitrate to encode a DV file captured from a VHS tape to h264 mp4?
By incubuscsg in forum Video ConversionReplies: 2Last Post: 4th Nov 2010, 17:30 -
Making XVID videos with VirtualDub: output files w/huge file sizes (~1GB+)
By maskingtape in forum Newbie / General discussionsReplies: 11Last Post: 5th Mar 2010, 00:50 -
Best program to re-encode XviD files to make them smaller?
By Benhermies in forum Newbie / General discussionsReplies: 1Last Post: 24th Apr 2008, 23:32
