Hey I just have a question, (might be quite newb but...yeah) is it possible to write multiple VCD MPEGs onto one DVD? Sort of like a compilation disk? And what application would I need to use to burn this?
Thanks in advance for your help,
Cabilo
Results 1 to 9 of 9
You can do it, but it can get tricky. Here's what I do;
IsoBuster to extract mpeg-1 files from the .dat files on the VCD
TMPGENC DVD Author to create the DVD.Working to protect intellectual property rights worldwide and the First Amendment rights of artists. Stealing music is a crime. http://www.riaa.com
There are two ways to do this:
1. Use an authoring program (or a conversion program coupled with an authoring program) to convert the VCD/SVCD data to DVD. This can be very simple with a good authoring program, just drag 'n' drop. It is, however, time consuming and you likely have less control. The conversion process is NOT a "newbie-level" thing. Also remember that DVD has a higher data rate for audio, AND a higher low-end resolution than VCD... so you can't fit as much onto a DVD as you might think.
2. Create a hybrid SVCD-DVD (with svcd2dvd, etc.) which works in SOME players but not all. -
DVDLab. About 3 clicks per movie, then burn.
I do it all the time. 3 SVCD's fit just about right.Cheers, Jim
My DVDLab Guides -
Originally Posted by Gurm
Also VCD resolution IS a standard DVD res.....christ.. whoes stupid enough to up that res?
My way of doing a VCD to DVD is (I aint saying its the only way)..I just find it quicker than letting the authoring prog (TDA in my case) do the audio conversion...
1) Extract the AVSEQ..DAT(mpeg file) from the VCD (using ISOBUSTER)
2) Demux into a m1v and a mp2 stream using TMPG
3) Convert audio to 48khz and my calculated bitrate (if required) using ffmpegGUI, either AC3 or MP2.
4) Author DVD with TMPG DVD Author...and create new tracks for each susequent VCD to be put onto the DVD.
Important note! TDA does not accept both PAL and NTSC m1v (or .mpg) files on the same disk.... -
Originally Posted by monzie
With the AC3 plugin, you can either let TMPG DVD Author do the conversion and keep the audio as MP2 converted to 48Khz or let it convert to AC3 audio.
I usually skip you steps 2 & 3, many time step one also. TMPG DVD Author seems to be able to accept the AVSEQ.DAT file directly for me. YMMV. The results seem good to me.
I would do a disk both ways on RW media and see how it works for you.
Cheers -
Note this is only true of VCD. DVD does not (as standard) support SVCD as a subset. -
Sorry I misspoke. It's a 48khz vs. 44.1khz issue, not a "data rate" issue.
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
Invalid DVD / Multiple errors with multiple programs...
By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 15:50 -
how can I write to a DVD+R DL
By agent222 in forum Authoring (DVD)Replies: 12Last Post: 12th Apr 2009, 14:08 -
Multiple VCD to single DVD
By Ryan Kelly in forum MacReplies: 7Last Post: 5th Apr 2009, 11:15 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 16:29
