Having problems deleting/moving/copying .avi files in windows xp?
Just so all you WINDOWS XP users know.. Virtual Dub 1.4.7 has problems frameserving in Winxp... check out digital digest's forum as well for numerous other accounts. Basically, you can fameserve with virtual dub, however, you will find that any .avi files will start misbehaving.. ie.. you can't delete them or move them or copy them as a message will say cannot (move/delete/copy) file as it is being used by another person or process.. it doesn't matter if you restart or not. I couldn't figure out why this was happening so I figured it must be something to do with converting movies.. so I went into the auxsetup of virtualdub and tried to uninstall the handlers.. it said I couldn't because one of the *.dll's was in use.. even after a restart.. the only way I could fix it was to go into safe mode, run auxsetup.exe, and uninstall the handlers.. then my avi files worked properly. Just a heads up for you all as I was VERY frustrated.
Hence
Results 1 to 1 of 1
Windows 7 AC3 Problems
By eon_designs in forum Video ConversionReplies: 3Last Post: 20th Apr 2010, 04:07 -
MeGUI problems since using windows 7 - PLEASE HELP!!
By qwertym in forum DVD RippingReplies: 4Last Post: 28th Mar 2010, 20:54 -
Still having driver problems with windows 7
By intheory in forum Newbie / General discussionsReplies: 1Last Post: 16th Mar 2010, 18:18 -
Windows Media Center .wtv 720p (60fps) to Xvid AVI (24fps) in Windows 7
By cg-realms in forum Video ConversionReplies: 0Last Post: 7th Jan 2010, 18:47 -
Windows 7 problems
By SEK in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 15th Nov 2009, 16:33
