    Jan 2003
    Brazil
    Dear Friends,
    Does any of you know if already exist any virtualdub that already can save on mpg2 format, or other program just like the tmpgenc that is able to open vdr files?
    Sinc.,
    J.J.
    Apr 2002
    The State of Frustration
    Well, if you load and configure VFAPI properly, the .vdr can be converted to a pseudo AVI file any application that convert AVIs to MPEGs will work.
    Hello.
    Jan 2003
    Brazil
    Well, As far as I know, VFAPI is used to create a pseudo AVI file from a D2V file, not from a VDR one.
    "Well, if you load and configure VFAPI properly, the .vdr can be converted to a pseudo AVI file any application that convert AVIs to MPEGs will work.
    _________________
    ...Hail! Hail! To Michigan!
    The Champions of the West!"
    Apr 2002
    Don't tell BJ_M that, He taught us how to do it, and if he finds out you doubt his wisdom, there won't be enough left of you to fit into an ash tray. There was this one guy named King John....
    Hello.
