I am aware that there is a verification option after burning in Nero...but what im looking for is a tool to check for the DVDs i have already burned in which i was not able to use the verification option in Nero. What im currently doing to check the dvd is try to create an image of the disk on my hard drive...if theere is no error then i consider it a good copy and definitely wont skip in my stand alone DVD player. Some of the DVDs i have were burned using CopyToDVD...and would like to check on these...
any input guys? thanks in advance...
DVDInfoPro will scan a whole DVD disc and report any read errors... This is probably what you are looking for....
DVDInfoPro can also compare a disk against a image file
Scanning the surface is a reasonably good test, but surface scans will only tell you if all sectors can be read, not how well they can be read. If the drive has to drop to ½X or ¼X to read a sector, it's likely to be a glitch or dropout on playback.
Personally I think a transfer rate test is much more indicative of overall disk and burn quality. Nero CD/DVD Speed does a good job, and it's free. -
I am using nero 5.5 version. Will CD/DVD speed work with that version?
Thanks skebenin. I downloaded it and checked a few of my backups. Fortunately they looked good.
Is there a tool to extract chapter data and timecodes from m4v files?
By ihudson in forum EditingReplies: 3Last Post: 27th Oct 2012, 12:17 -
Dvd Lab Pro 2.5 Pre Verification fails / Compile.aux error
By Ultron in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2010, 21:45 -
DVD-R media and verification errors
By rotuts in forum MacReplies: 9Last Post: 23rd Mar 2009, 13:17 -
dvd verification
By blas in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2007, 08:16 -
Nero 7 data verification failed....?
By LoneWolf1038 in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2007, 08:06
