I tried to encode a DivX file in Ffmpegx (the output was supposed to be a dvd-file, can't remember the name). After seven hours (!) the progress was cancelled due to some error. Am I doing all just wrong? Should I use another program to encode the Divx file to a working dvd-file which i can then burn?
Subtitles would also be nice...
Talking about the subtitles, haven't gotten the subtitles to work in Quicktime. I've tried to export the .srt files from SubSyncX but Quicktime still won't play them. Just a white square in the top left corner where subtitles show, but the movie disappears...
Please help, going nuts over here...
...and I know about the existence of MPEG2WORKS but haven't got the money so please help me with something else than that
hi,
MPEG2Works does the job. it is not expensive. if you are not willing to
support good software for a fair price so nobody can help you.
i dont believe that the 10 buck are to expensive for anybody.
no regards here -
Well that was really helpfull. The fact is that i dont own a credit card. Are you really saying that there is only one program that can do the trick!?
no, but as you will see there is really only one program that takes the headache away
its still the same problem, how to go from that to dvd
if you do that, it only allows you to open the .avi in quicktime, and then exporting to mpeg2 would work but you only get video, so you then have to demux the .avi and recombine the .m2v from quicktime in some sort of authoring app
can be done and if you want give it a try, but i recommend the mpeg2works method
the app is not very expensive and its worth every penny when you see how good it works
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
making dvd;s
By brenjim in forum Capturing and VCRReplies: 2Last Post: 14th Jul 2007, 11:48 -
Need advice making Episodic DVD with DIVX files - play on compat DVD player
By Firewire60 in forum Authoring (DVD)Replies: 5Last Post: 16th Jun 2007, 21:41
