bear with me...
if I wanted to take an oscillator or signal generator, hook it up to a TV and see a signal, what frequency range would my signal gen need?
and what would I expect to see if the signal was a sine wave as opposed to a square wave, for instance?
any info / links / tips appreciated.
- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
You're looking for VHF and UHF frequencies on a regular TV. Are you looking for or trying to send to a specific channel?
Analog video has various signal components ranging from near 0 Hz to over 6 Mhz (which is also the bandwidth of analog video).
You will see a sawtooth wave for the CRT and a square wave for the components:
www.cs.tcd.ie/courses/baict/bac/jf/labs/scope/oscilloscope.html
*use the links at the bottom of page for more info. -
basically, what I'd like to do is hook 1-3 frequency generators to a coax cable and run it into a tv, see what I get.
ideally I'd get some wack visual that I can manipulate in real time by fiddling with the controls on the sig gens.
does that narrow the ranges any?- housepig
Housepig Records
out now:
I tried that once, during a storm. Then the voices started
Nothing can stop me now, 'cause I don't care anymore. -
TV signals are pretty complex. You would be wasting a lot of time with just a RF signal generator.
This site has a good explanation. http://entertainment.howstuffworks.com/tv.htm
Take a look at the page titled 'Video Signal'. That is one line of composite video with no video information.
Your computer would do a much better job with generating video. A good example is when Windows Media Player generates a random pattern for sound files with no video. -
Originally Posted by redwudz
thanks for the link!- housepig
Housepig Records
out now:
Artefacts when streaming a high frequency signal through S-VHS
By mamoltub in forum Video Streaming DownloadingReplies: 5Last Post: 24th Apr 2012, 09:46 -
Video Processing Signal Chain Question
By generallee in forum Capturing and VCRReplies: 2Last Post: 23rd May 2011, 03:33 -
S-Video Source/Signal Type Question
By generallee in forum Capturing and VCRReplies: 2Last Post: 23rd May 2011, 03:31 -
Getting extended range WiFi question
By Noahtuck in forum ComputerReplies: 8Last Post: 23rd Dec 2009, 23:36 -
Digital TV Signals - Changing Frequency Question
By Frank-0-Video in forum DVB / IPTVReplies: 0Last Post: 2nd Feb 2009, 17:48
