Is there any good source out there that goes over capturing video from the web such as from sites like MTV/VH1/Launch and sites with quicktime video? I know the quality of these videos are pretty low but would still like to be able to save them to my hard drive.
Results 1 to 11 of 11
Download Camstudio. It'll take anything from your desktop and make it into an AVI file
You can set a custom capture area. Verrrry handy little app -
I've used a program called CapturePad. There is a freeware version here - http://www.capturepad.com/freeware.htm
I'm sure there are better things out there, but it has worked for me, and it allows you to save using most any codec you have installed on your system. -
are these the only two options? Is their a way to capture the source directly??
Originally Posted by K_cin_az
yeah, the MTV videos you cant save as and caputre pad nor cam studio will record them either....i will maybe look into these others....has to be some way to grab the video
Cam Studio should record everything that appears on your desktop, like this one I used it for:
If you see it, it should grab it. Do you get an error, or does the capture end up being blank? -
well on mtv videos is captures everything except where the video is playing it is blank...
http://www.mtv.com/bands/az/k_os/audvid.jhtml
for example the crucial live performance video, ive tried capturing full screen and just the area of the video, caputures audio but not that video -
I am having a problem with Camstudio. I used to use it, but haven't tried in it in awhile. however, when I tried it today, it seemed to record ok, but when I tried to save it it said "File creation error- unable to rename/copy file. The file may be opened by another application." However, no other applications should be using any part of this program....any ideas?
http://www.xi-soft.com
It locks onto a stream and downloads the root file behind it. Downloading Net Transport is free but the author does ask for "donations" on his site.
Capturing Web Cam Through Adobe Flash In Browser
By johnsmith153 in forum Video Streaming DownloadingReplies: 0Last Post: 11th Jun 2010, 17:35 -
capturing from web
By wingfan in forum Video Streaming DownloadingReplies: 4Last Post: 12th Dec 2008, 17:32 -
Capturing ready-to-go AVI for PC/Web use
By hollowman in forum Capturing and VCRReplies: 0Last Post: 18th Aug 2008, 23:47 -
web capturing divshare
By nirbhayn in forum Video ConversionReplies: 1Last Post: 9th Dec 2007, 05:18 -
Capturing web stream
By peter762033 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 11:47
