Hi guys,
When burning an mpeg video in Nero 6 onto DVD disc, which option do I use?
I want to be able to play it on my DVD player in the living room. Do I choose the data disc on the DVD tab, or Disc image or what?
When I choose the DVD tab then "Burn DVD video files" I can select the mpeg file to put into the Video_TS folder, but immediately it says "No compatible file found"
Thanks for any replies.
Results 1 to 10 of 10
Hello,
dvd video files probably means the completed video_ts folder. You need to author the mpg to burn it to disc.
Use whatever language is needed to author the mpg into a dvd. It should let you import the mpg and make a menu/chapters out of it. Then it will create a video_ts folder with the vobs in it. That's what gets burned onto the dvd.
Kevin
--also, is your mpg dvd compliant???---Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
"is your mpg dvd compliant?"
Dont really know. How would i find out?
Is authoring the mpeg easy to do? -
Hello,
Bitrate viewer will let you know. It should be mpeg2 with a bitrate over 2000 and a resolution of 352x480 or 720x480 (ntsc) and 48khz audio. (there are a few more exceptions but those are the basics).
Authoring is merely desinging the layout of the menus. The program will do the dirty work. You can put pictures or videos in the background depending on how complex your version of nero is.
Ok Kevin thanks for your reply.
I ran the Bitrate viewer and got these results
Num. of picture read: 138134
Stream type: MPEG-2 MP@ML CBR
Resolution: 720*576
Aspect ratio: 16:9 Generic
Framerate: 25.00
Nom. bitrate: 5000000 Bit/Sec
VBV buffer size: 112
Constrained param. flag: No
Chroma format: 4:2:0
DCT precision: 8
Pic. structure: Frame
Field topfirst: No
DCT type: Frame
Quantscale: Nonlinear
Scan type: ZigZag
Frame type: Progressive
Notes:
Bitrate peak = 5588, average = 4883
Q.level = peak 14.27, Average = 5.59
There results really mean nothing to me! But maybe to you they do! -
Hello,
Ok that means you have a pal dvd compatible mpg file. Just go ahead and load that into the authoring portion of Nero. I don't have nero so I can't tell you exactly where to go. Just find the tab that says dvd creation, or dvd authoring, or make a dvd. Something like that so you get an option to make the menus and chapters and etc...Originally Posted by donjayok
Shouldn't be too difficult.
Kevin
[/quote]Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
donjayok,
Use Nero Vision Express 2(if you have it) to author,if not try TMPGEnc DVD Author. -
Ok thanks so much guys.
I will use the TMPEG authoring program as the Nero 6 Ultra Edition doesnt have this authoring feature. Well I cant find it anyway!
Thanks again. -
Hi guys,
Just to let you know the TMGEnc DVD author program done the trick.
Thanks so much for your time and expertise.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
ImgBurn and Nero will not burn backup DVD
By rcguy1 in forum Newbie / General discussionsReplies: 4Last Post: 29th Jan 2008, 09:05 -
Can't Burn from Mpeg-2 to DVD (Nero Software & Pinnacle Capture Card)
By bpatters69 in forum Authoring (DVD)Replies: 14Last Post: 9th Nov 2007, 07:35 -
How to burn DVD data with Nero 7?
By Kakui in forum Newbie / General discussionsReplies: 5Last Post: 28th Oct 2007, 16:00
