I install V3 beta, all went fine. I ran it had a quick test and all was good. Later on after I had rebooted my computer It wouldn't run and I got this problem
any ideas anyone?Type: System.NullReferenceException
Source: Interop.CodeLock
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at CodeLock._Secure.Authenticate(String pass)
at AxCodeLock.AxSecure.Authenticate(String pass)
at SVCD2DVD.210ff09a2516b1a7.41f470203acc6a6e()
at SVCD2DVD.210ff09a2516b1a7.0507e45eec4e9097(Object e0292b9ed559da7d, EventArgs fbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.ThreadContext.RunMessageLoopI nner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.ThreadContext.RunMessageLoop( Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at SVCD2DVD.210ff09a2516b1a7.c447809891322395(String[] ce8d8c7e3c2c2426)
did you edit your boot.ini to resolve the DEP issue?
Audacity Mac 1.3 Beta - solved my problem but how?
By Rhymester in forum AudioReplies: 5Last Post: 27th Oct 2011, 09:43 -
VHS vs Beta
By robjv1 in forum MediaReplies: 54Last Post: 21st Oct 2009, 01:45 -
Beta? what is it
By Stephanee in forum ComputerReplies: 3Last Post: 5th Nov 2008, 10:58 -
Problem Starting up Beta 2.5
By mwkurt in forum SVCD2DVD & VOB2MPGReplies: 27Last Post: 14th Jun 2007, 04:42 -
Beta 2.5 download?
By hordak in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 3rd Jun 2007, 05:59
