Hi all, hope your all well,
O.K just wondered if anyone would be able to help with the problem i'm having.
I'm using DVDsanta & Cucusoft to convert avi movies into dvd, now on playback the talking is out of sync with their mouths, when i play the original on my pc using wmp it's fine, can anyone shed some light what i could be doing wrong??
Is the audio in your AVI file Variable Bitrate MP3?, if so, that could be the problem... Get Virtualdub and load up the AVI files, it should then tell you if you have Variable Bitrate MP3 audio...
Hi mh,
i opened the video file into virtualdub and i got the following message:
Virtualdub has detected an improper VBR audio encoding in the sorce avi file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 41743 ms of skew from the video stream. If this is unacceptable, decompress the entire audio stream to an uncompressed WAV file and recompress with a constant bitrate encoder.
This has lost me
Just do exactly as it says. Open the file up, OK that message and save the audio as WAV. Then use your favourite audio editor to compress it into CBR MP3 (eg. 160kbps). Then use VirtualDub to open the video file save it using the new MP3 file as an audio source. That should sort out the problem.
Also, please try to choose a subject line that describes your problem. Subjects such as this are often simply passed over by most users - you will not get a decent answer quickly. Also, it makes forum searches more difficult for other users with the same problem.
Cobra -
Hi cobra
I done as you say, and am having trouble saving the movie with the mp3 i converted not sure where to go, if i go into audio it says save WAV but not mp3.
I apologise for the title of my post also
Help Converting an ISO Image File into a DVD Format playable on DVD players
By Gradyj in forum Newbie / General discussionsReplies: 5Last Post: 19th May 2010, 21:13 -
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 10th Apr 2009, 00:56 -
Converting/examining my video files and converting to have less pixelated?
By SimpleSimon in forum Video ConversionReplies: 51Last Post: 29th Aug 2008, 00:33 -
Converting .VRO file onto a DVD disc (to play on standard DVD players) ?
By superman123x in forum Video ConversionReplies: 21Last Post: 24th Mar 2008, 18:40 -
Converting songs purchased on itunes and converting to mp3
By maroonx in forum AudioReplies: 1Last Post: 23rd Jan 2008, 01:17
