Results 1 to 13 of 13
  1. I have a DVD which I want to fix. It appears like the picture has been resized from the original (I think letterbox) to fit fullscreen. The result is a stretched picture. Can I resize to normal without losing quality?
    Apr 2004
    Miskatonic U
    The disk is fine. It is in a format known as Anamorphis, or widescreen enhanced, or 16:9 enhanced. The image has been encoded this way to capture more data. On a widescreen television, the picture will be compressed back down to normal height. If you are watching a standard format television, and seeing the picture stretched like this, then you have not set up your DVD player correctly. In the settings for your player you should find a setting aspect ratio. Yours should be set to Letterbox, not widescreen. The player will then do the conversion for you.
    Read my blog here.
  3. Thanks for the advice but unfortunately this is not the case. I changed the aspect ratio on my DVD player, nothing happens. Besides I forgot to mention the disk is a DVDR recorded on a set-top DVD recorder. It has menus similiar to the ones generated by Panasonic. So I am stuck with a deformed movie.
  4. Is it possible that the original recording was recorded in PAL (European),
    and then converted to NTSC?
  5. I had it shipped from Europe so it is still in PAL. My player plays PAL and NTSC, and I can easily make a NTSC copy on my Panasonic recorder because it is not protected. The problem is the stretched picture. And I am looking for a software which might help me do the resizing to correct height.
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Tmpgenc has a resize function that will squeeze the vertical resolution down and fill out the balance with black to preserve the resolution. Have a look at the to begin with.
    Read my blog here.
  7. OK thanks. I will try that.
  8. Hey Guns1nger,
    I need some more help. I have TMPGenc DVD Author and TMPGenc Plus 2.5. I was planning to load the movie in TDA, use the "Save to HDD" function and have a big mpg file and work with it in TMPGenc. Can I do that? I tested TMGenc last night a little bit. I used the wizard's "clip frame" and then selected "center (custom)" option where you can actually resize the display manually and preview the outcome. My question is will TMPGenc handle a whole movie and what do I have to do so I do not lose audio. I tested the output mpg file in winDVD and Windows Media Player and I had no audio.
    I would really appreciate your help.
  9. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Widescree is a attribute, you can have have a 720x480 in either 16:9 or 4:3. This information is in the header file of the video or the ifo file on the DVD. The videos on your DVD will be either flagged as 4:3 or 16:9, the DVD player will adjust the aspect ratio as needed. Using DVD Workshop I can have both 16:9 and 4:3 on the same DVD and have them display properly. Apparently your video has been flagged as 4:3.
    You need software that supports 16:9 or you can edit the ifo file.
    https://www.videohelp.com/forum/viewtopic.php?t=242338&highlight=
  10. This seems much easier but I am not familiar with ifoedit. Any particular guide I should check?
  11. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Don't know, just know it's possible. I've never had to use it because all my video has the correct ratio to begin with.
  12. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    I know that a lot of studio disks are not properly set. I have a 4:3 TV with 16:9 switching capabilities. A lot of major studio disks (Paramount is a big offender) do not switch correctly.
    Do a search of the guides for Ifoedit. The first one I found was this
    https://www.videohelp.com/guides.php?link=506
    which seems to be a bit of a catch all lit of tips, including aspect ratio changes
    Read my blog here.
  13. So if I do the following modification in ifoedit the aspect ratio will change from "stretched" fullscreen to widescreen?
    VTS_01_0.IFO (original)
    Title Set (Movie) attributes:
    Video: MPEG-2 352x576 (PAL) (PAL 625/50) (4:3) (not specified perm.display)
    VTS_01_0.IFO (modified)
    Video: MPEG-2 352x576 (PAL) (PAL 625/50) (16:9) (not specified perm.display)
    I am also not sure if I should modify the "VTS_01_0.IFO" or the "VIDEO_TS.IFO" or both?
