I use tmpgenc 2.52 to convet my xvid file to dvd format.Then i use tmpgenc dvd author to author the disk, i then use nero to burn the dvd on dvd-r or dvd+.The problem is i have 2 dvd players and the dvds only work on the _phillips dvd 633_ and not on my Awia xd-ax36.If i use mainconcept mpeg encoder the files are lots bigger than the files tmpgenc 2.52 creates and the quality is not as good but they work on both dvd players.Any ideas.Whats tmpgenc doing wrong or different.
Marginally crappy media perhaps? Some players are very sensitive to the media you use. It's partly because of the reflective layer of the disc, from what I understand of it which is very little.
You might have found a media that the Phillips likes and the Aiwa doesn't. -
Sounds like when you select LPCM audio it works, but the files are huge. So it's a compatibility issue. The other sound format is smaller but they don't play it.
What audio format are you using in the TMPGEnc setup for the output file? It should be AC3 or MP2. Those are compatible with all reasonably new DVD players. Only the very early NTSC players required LPCM audio for compatibility. -
Capmaster, this could be the problem! TmpGenc DVD Author by default does mp2, which is supported by most but not all DVD players. Maybe your DVD player does not support mp2 audio. The DVD spec requires AC3 or LPCM. TmpGenc DVD Author will only do AC3 if you buy the plugin. I'm guessing this is your problem...What audio format are you using in the TMPGEnc setup for the output file? It should be AC3 or MP2.
Jeanl
Netflix prices going up again, a lot this time
By jagabo in forum Latest Video NewsReplies: 102Last Post: 18th May 2012, 19:00 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
How to convert a video without wasting file size and reducing quality?
By tendra in forum Video ConversionReplies: 2Last Post: 29th Oct 2009, 07:24 -
Wasting my time recording videos in high definition?
By cameraz in forum Newbie / General discussionsReplies: 8Last Post: 6th Aug 2009, 16:29 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24
