Results 1 to 15 of 15
  1. I have a load of old VHS rips of old TV shows on my HD as AVI files, I have vegas video 5, and want to use some virtualdub filters to clean up the video. I know you are supposed to be able to use them directly without frameserving, but I cant figure out how to import the filters into vegas. any ideas?
  2. bransholme - this is not going to help you directly, but did you search the forum? This came up sometime in the past few months and I think the post explained how to do this..maybe from BJ_M as I think he's a vegas user
    "As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
  3. Member Safesurfer's Avatar
    Mar 2004
    I know you can do this by using Wax 2 which works as a plugin for Vegas. Not sure if you can use Vdub filters directly in Vegas.
    "Just another sheep boy, duck call, swan
    song, idiot son of donkey kong - Julian Cope"
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    get wax from debugmode.com, install, and you can use many v-dub filters directly in vegas ....
  5. thanks, will try that.
  6. wax crashes vegas for me every time.
  7. Member Safesurfer's Avatar
    Mar 2004
    In Wax (launch as standalone), go to Edit - Preferences, and uncheck "Use 3D Hardware Acceleration" this can cause crashes for some users. If this is already unchecked, or doesn't fix the problem, leave a message for Satish on the Debugmode.com forum - he's very responsive.
    Edit - Also just saw the check box for "Use Dummy Host Media in Wax Plugin for Sony Vegas" - might give that a try too!
  8. Член BJ_M's Avatar
    Jul 2002
    Canada
    Safesurfer is right on both counts .... should fix it right up .... hardware Acceleration only works on some cards (not sure which)
  9. Hi All,
    I am trying to find an easy to use Subtitling software, I look in the forum and saw Virtual Dub, which work with SSA, I downloaded vdub, but when i tried to dl ssa, I was redirected to a Portuguese web site which I cannot read. Can someone please help me to find a reliable easy to use subtitling software
    Thanks and Regards
    FFL
    Thanks and Regards
    FFL
  10. Did I mention FREE
    Thanks and Regards
    FFL
  11. Member erratic's Avatar
    Oct 2003
    Belgium
    If you want the subtitle filter for VirtualDub, it's on the VDub website.
    http://www.virtualdub.org/virtualdub_filters
    A whole bunch of subtitle tools.
    http://www.divx-digest.com/software/index4.html#subtitles
  12. Wow Eratic,
    thank you very much, I will give a try
    Thanks and Regards
    Thanks and Regards
    FFL
  13. ForeighFilmlover - please do not threadjack. If you have a question, start a new thread for it.
    This is an informal warning.
    / Moderator Cobra
  14. Sorry Cobra,
    I am new to the forum and still trying to find my way around. So sorry for the inconvinience.
    Thanks and Regards
    Thanks and Regards
    FFL
