I hope someone can help me with this problem.
I'm trying to join 2 avi files using virtualdub P4. When I select the "append avi segment" option and add the second avi file I get the following error message "the audi streams have different sampling rates"
I've had a look on Google and one solution was to use virtualdubmod but it didn't tell you how.
Is there a way around this?
Thanks in advance
You need to use VirtualDub to take the audio out of one of the AVI segments (save it as a WAV), then use your favourite audio editor to change the sampling rate to match the other file. Use VirtualDub to re-integrate the audio with the video on the altered segment, and you should then be able to join them.
Good luck,
Cobra -
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 13:52 -
Joining AVI Files
By wulf109 in forum Video ConversionReplies: 4Last Post: 4th Nov 2010, 15:17 -
Joining avi files?
By t_jay17 in forum EditingReplies: 5Last Post: 18th Dec 2007, 13:22 -
joining avi files
By king2136 in forum Authoring (DVD)Replies: 4Last Post: 1st Oct 2007, 15:30 -
Problem Joining AVI files with MEncoder
By RetSpec in forum EditingReplies: 1Last Post: 6th May 2007, 23:00
