I'm looking for a Time Base Corrector but cannot make my mind up between a card and a stand alone unit.
I've read so many posts my mind is going round in circles, but so far a couple of questions I have not found the answer for is:
A stand alone unit often has colour/tint/contrast options. Does a card have the same?
Does the card take any power away from the processor ie slow it down?
Advantages/Disadvantages?
Results 1 to 30 of 45
AFAIK a lot of those plug in card TBCs only use the power supplied by the slot.
Good decision
I always recommend a TBC for marginal source capture, and especially for tape capture.
DataVideo makes a nice unit in the card or standalone configuration. I don't believe they offer a TBC with color/chroma controls in the price range you're looking for, but then, are you looking to buy a TBC or are you looking for a video processor?
Their basic TBC is a 4:2:2 full-frame unit with a frame synchronizer as well. -
I personally went for a card type TBC, totally on cost. I know that a lot of mfrs sell basically the same electronics as either a card or a stand alone box - but with the stand alone box you have to pay extra for the additional case, power supply etc, and maybe shipping weight, and I wanted to keep the cost down.
On the other hand, the only drawback I've noticed with the internal card route is the extra spaghetti hanging off the back of the PC.
IMHO you don't need fancy knobs on your TBC. All you need is a reliable way to get the data onto your PC. Once the video is available on your PC you can easily run it through filters and so on for DNR or color balance, or whatever. -
Thank you Capmaster and mpack. I appreciate your replies.
I do have a video processor - a VEC1070 - so the colour/tint options are not that important. I was mainly thinking of having everything in one unit.
I'm capturing VHS via a Datavideo DAC-100 so might possibly go the Datavideo way -
Well saidOriginally Posted by mpack
My sentiments exactly.
Good choice. I have the TBC-1000 and I absolutely love it. Rock-solid. It also has a 4-output distribution amp built-in. I don't believe the card model has that feature, I may be wrong, but unless you're setting up a tape dupe operation it probably isn't that big a deal. I only use one output myselfOriginally Posted by Ramon
The TBC-1000 runs at about 420/450 Euros (298GBP) inc postage. I'm impressed with the DAC-100 so will probably bite the bullet and stay with Datavideo. Not sure if I'd usethe 4-output distribution amp but perhaps I'll find it useful at a later stage.
Thanks again mpack & Capmaster. -
The higher-end TBC's usually have the color/adjustment controls on them, and make a viable unit but most of them are beyond the reach of those with limited funds. Usually those type units do alot better with color adjustments and such that software-based filters based on that hardware units are more dedicated for the task.
For your purpose though the TBC-1000 is a great choice for getting the video stabilized before going into the PC. I have one and it works great. I transferred an old home video for a friend of mine and before the TBC I dropped like 2-300 frames in a short period of time. After the TBC, didnt drop a single frame. The 4-output dist amp is when you want to hook up 4 VCR's and record to them at the same time from one input. Its worth the cost.
VTMI have the staff of power, now it's up to me to use it to its full potential to command my life and be successful. -
Thank you VideoTechMan - I think I've now decided to definitely go with the TBC-1000.
Many thanks to all for the advice given, it is appreciated. -
Has anyone played with this little beasty - seems to offer a lot http://www.videoguys.com.au/scripts/prodView.asp?idproduct=460
Read my blog here.
I actually did look into that a while ago and posted a link here as well. The sales dept resonded to my email the very next day. It can act as a standalone TBC in addition to a bidirectional A->D converter. Kind of like a TBC-1000 combined with an ADVC-100 from what I gather. Roughly $600. I kind of shyed away since I couldn't find any reviews on it. I think it's brand new as well.....Originally Posted by guns1inger
richdvd - not sure what you mean. I had a look at the link you gave guns1inger, but that's serious money to me. Don't think I could justify it on my pension!
Those prices are in AUS$, but it would still be around the US$750 mark.
Based on AUS$ prices, I could go with the TBC-1000 AUS$580) and the ADVC-100 (AUS$580), and do all the processing on the PC, or for AUS$100 more, get all some good enhancement done during the capture.
The cheapest alternative would be the TBC-100, but analogue capture eats a lot of space.Read my blog here.
Thanks again guns1inger - I've more or less made up my mind to go for the TBC-1000 (it's not written in stone though so could change)
The only two consumer TBCs I can think of in the $200-$300 range is the TBC-100 and the AVT-8710. You can find many TBCs on ebay but a lot are rack mounted units with BNC type connectors. The AVT-8710 is a bit cheaper but some people have said there are problems with vertical lines in the picture...Originally Posted by Ramon
Thanks fmctm1sw - I don't mind going up to about 450 Euros (570 USD) but more than that and I'll have to eat the dogs dinners (and they won't be too pleased).
The ADVC300 might be best. That allows to hook up pretty much anything to it and digitize it.
dvd3500 - I'll certainly have a look at it (figuratively speaking as no-one seems to deal in such items out here so I have to go via the mail order route)
Just checked Ebay - they have a Prime Image currectly at $100 which will probably spiral up to 6/700 by the time it's finished. -
Now you're getting your video priorities straight
Note: The TBC-1000 can be had here in the states for about USD$280. -
care to say why?Originally Posted by richdvd"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
When he says it's the shit, he means it's good. At least, I'm 95% sure he means it's good. I guess there's a slight possiblity that he's not using the slang version of "<blank> is the shit" and really means it's not good.Originally Posted by Ramon
Although maybe you guys realized this also and are actually asking him to give reasons why he likes it. -
I have a related question:
The TBC-100 only has video inputs and outputs. The TBC-1000 has inputs and outputs for audio also. Does the TBC-1000 do anything with the audio, or just pass it through? The main reason I ask is because I'm considering purchasing either the TBC-1000 or the AVT-8710, and the AVT-8710 also lacks connections for audio. -
Translation: Datavideo TBC-1000 is a fine piece of equipment and is far superior to any other.Originally Posted by DaveS
Easier to say "The shit" or "Da shit" or "Da shiznit"
The TBC-1000 doesnt do anything with the audio, it just processes the video. So pretty much the audio ports on there is just a pass-thru.Originally Posted by Brent212
Good to know. It still strikes me as strange that they are there at all. Why would anyone want to waste an extra audio cable? Maybe if one wasn't long enough...Originally Posted by VideoTechMan
Canopus does not make a TBC. They include a flimsy line TBC (not a full TBC!) in some of those DV converter products, and they're quite poor. Much like the Panasonic DVD recorder TBC's, they may as well not exist, as they do near nothing.
Website with TBC-100 (includes Diagrams and pinouts, w/ specs)
* http://www.solomonav.co.kr/products/tbc_100_main_page.htm
This is the card I have and use sometimes (in some cases, under certain
cercumstances) This one (in the pic) does not have any audio connedtors or
jacks on the board.
However, the card I have, *actually has* connectors for both IN and OUT
next the the Vid In and Vid Out pins (on the board) The diagram that came
w/ *my* board did not describe these connectors but they are definately
audio connectors. I haven't tried them, because I really don't need to do any
thing with the audio, since I use my soundcard for that already.
My board may be an updated version, but the documentations were not
revised/updated to reflect this
-vhelp
Time Base correctors
By Spektre in forum Capturing and VCRReplies: 8Last Post: 22nd Aug 2011, 23:50 -
Time Base Correctors
By josel in forum Capturing and VCRReplies: 4Last Post: 10th Nov 2010, 13:01 -
Time Base Corrector Information
By Sprout in forum Video ConversionReplies: 4Last Post: 11th Apr 2010, 04:33 -
Do I need a Time Base Corrector? If so, which do I get?
By Smack2k in forum Capturing and VCRReplies: 3Last Post: 11th Jul 2008, 11:41 -
Anyone try the TV One 1T-TBC time base corrector yet?
By heman31 in forum RestorationReplies: 0Last Post: 15th Sep 2007, 18:20
