this has happend to me twice now.... after i decrypt my movie i open dvd shrink hit open files select the movie i just decrypted and a window pops up saying "dvd shrink encountered an error"
"failed to open file c:/ movie blah blah"
"the system cannot find the file specified"
anyone know how to fix this?
thanx
JD
Results 1 to 10 of 10
Are you playing the main movie when you try to rip. Give that a try if you're not.
Hello. -
i cant even get the movie open in dvd shrink
what if i just shrink the movie without decryping it , when its done encoding will it just stop and not burn cause it aint decrypted? -
Play the movie in your computer's DVD player. While it is playing, open DVD Shrink and try to rip.
Hello. -
Have you tried using DVD Shrink to rip your movie, and not DVD Decrypter?
Hello. -
does your movie blah blah directory exist ?Originally Posted by jxD
seriously though...
Use this ripping guide and then try to open it in DVDShrink.If in doubt, Google it. -
And sometimes all you need to do is open a SW player and begin to play it. Then close the app. That simple action "unlocks" the DVD for other apps to access. It doesn't happen all the time that it will remain "locked" and require this, but it's handy to remember, and try it. It wouldn't hurtOriginally Posted by Tommyknocker
Hi,
If you use DVD Encrypter and change save directory even you take same which from Decrypter choice. You have to follow this typing:
Ex: "Your DVD name"\VIDEO_TS (VIDEO_TS : should be in capital letters)
Then you can see it under DVD Shrink program. That work 100%
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 23:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 24th Sep 2007, 00:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 18:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 22:31
