Im capturing with MainConcept , VirrtualVCR or PowerVCR to convert my VHS tapes to SVCD or DVD. I ve found that for DVD os SVCD Mpeg2 its better to do the job with MainConcept. I think that there is no reason to capture in avi and then convert to mpeg2 since it needs 1 additional step so I concluded to do the job straight to mpeg2.
But the sound i get is distorted. Any ideas? Should I plug the audio from VCR to capture card or to sound card?
Thanks in advance
try plugging it into the one you dont have it plugged into now ..
or better yet = turn it down ..
if you have a audio and video being captured by two different things -- sync can (most likely) become a problem"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
make sure you are not plugged into a mic input also ..
Easycap USB adaptor and Windows Vista Ultimate - Sound distortion problem
By Eric544 in forum Capturing and VCRReplies: 4Last Post: 10th Jun 2011, 16:52 -
Sound distortion when play CD on Magnavox ZV457MG9A
By AliceWonder in forum AudioReplies: 1Last Post: 12th May 2011, 12:16 -
Audio distortion
By silveringking in forum AudioReplies: 0Last Post: 26th Jan 2011, 17:13 -
Distortion when played on TV
By tomhopkins in forum Authoring (DVD)Replies: 4Last Post: 18th Jul 2009, 16:36 -
So much noise/distortion :(
By Lee82 in forum Capturing and VCRReplies: 1Last Post: 23rd Aug 2007, 01:14
