Hello,
Simple.... Use an authoring program to make your dvd menu. Then use dvdshrink to shrink that video_ts folder. Since it is just a little over the size of a dvd-r (single layer) you won't have much of a quality hit.
Kevin
(this will make a second video_ts folder so make sure you have an extra 4.5gb of harddrive space - actually more than that - the 4.9 gb file will author a 4.9gb folder than load it into dvdshrink to knock it down to 4.37gb so you'll need 9gb of extra space)Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 5Last Post: 24th Sep 2015, 18:29 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 05:02 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 18:31
