Hey everyone, what's up? I just got a DVD Burner for the first time, so I have been experimenting with different apps, and I came across DVD Santa. I made a few DVDs's using the program, converting avi's to DVD, with pretty good success. I have to Nero to burn, as DVD Santa errors when it tries to burn. Anyway, I came across a small problem, and I hope it is just something I have overlooked. When converting avi's with the same aspect ratio, all seems OK, but what about when the avi has different aspect ratios? You can only select 1 aspect ratio for the whole project, not for each individual file.
So I was wondering if I just missed something, or is this a limitation of the software.
Thanks so much for your time!
Hello,
You can use virtualdub or maybe even tmpgenc to convert the aspect ratio to match the others.
There should be something useful in this section:
https://www.videohelp.com/convert
Just look through the guides and it should be listed
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Aspect Ratios: 0.889 vs 0.9191
By Hass860 in forum Newbie / General discussionsReplies: 15Last Post: 13th May 2010, 04:14 -
iMovie and aspect ratios
By sphinx99 in forum MacReplies: 3Last Post: 11th Mar 2010, 00:18 -
multiple aspect ratios on one DVD?
By towtruck in forum Authoring (DVD)Replies: 11Last Post: 7th Jul 2008, 03:58 -
Converting to Divx and Aspect Ratios
By matthewjohn23 in forum Newbie / General discussionsReplies: 8Last Post: 28th Mar 2008, 18:43 -
Aspect Ratios
By gayclarke in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 16:13
