I bought an 80 G firewire external hard drive in March to use exclusively for editing DV video. Didn't really use it until a few weeks ago. It doesn't want to initialize (be seen by the computer) without turning it off and on 12 or 15 times.
I've tried turning ExHD off, rebooting PC, let PC initialize and then turn on ExHD. Tried turning them on at the same time. Tried turning the ExHD off and on while computer is running.
Is there a routine I should be following for success?
LynnsABCs
I would try to remove the firewire card, boot the PC. Then reinstall the firewire card. If might be going bad. I had a similar situation with one of my USB2 external drives, and it turned out to be the USB2 card.
external hard drive
By alintatoc in forum ComputerReplies: 20Last Post: 26th Sep 2009, 19:54 -
Problems putting a NEW Drive in an OLD External firewire box?
By phase52001 in forum DVD & Blu-ray WritersReplies: 3Last Post: 30th May 2009, 21:03 -
Problems with DVP5990 and External Hard Drive
By maryp1987 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Apr 2009, 19:28 -
External Hard Drive > TV?
By jason in forum Newbie / General discussionsReplies: 36Last Post: 12th Mar 2008, 09:32 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 08:47
