What happened was if I leave my computer idel for a period of time (say 2 hours) then tried to surf the net again, my router would not response (i.e. the green light will not blink, as it would when receiving data). I had tried getting into the router's management software and clicked "rescan" with no luck. Only way was to reboot the computer in order for the router to work again.
Any suggestion on how to fix this problem?
My initial setup:
Sony Visio 1.8Ghz running WinXP Home with SBC DSL.
D-Link AirPlus G DI524 802.11g wireless router;
D-Link AirPlus G DWL-G510 802.11g PCI adapter; &
D-Link AirPlus G DWL-G120 802.11g USB adapter.
Thanks for any info in advance.
I'm a nobody, and nobody's perfect...so I'm perfect!
Sounds like somehow there's power management built-in and it's going to a power-down standby state, and not waking up. Any power options in the setup for the router?
Good point...I don't know. Will check it tonight when I get home from work.
Thanks!
I'm a nobody, and nobody's perfect...so I'm perfect! -
Originally Posted by Byronleehk
Good luck with that
Capmaster, you were right! I had the router set on 'power save' mode so I changed it to 'continuous power consumption' (or something like that) mode...didn't wait for 2 hours to see if it works again but at least you pointed me to the right direction.
Thanks again.
8) You're welcome. I think that's what it was, and I'm sure you won't have any more trouble with idlingOriginally Posted by Byronleehk
wireless router
By alintatoc in forum ComputerReplies: 6Last Post: 14th Feb 2010, 05:59 -
Wireless Router Help!
By Nitro89 in forum ComputerReplies: 8Last Post: 10th Feb 2008, 06:22 -
Can a router/wireless router shut down computer?
By tmh in forum ComputerReplies: 7Last Post: 29th Jan 2008, 13:34 -
how to limit speed of users on wireless network (router-lan-wireless)
By deejay.2001 in forum ComputerReplies: 5Last Post: 3rd Nov 2007, 00:56 -
which wireless router should i get?
By Ade007 in forum ComputerReplies: 11Last Post: 2nd Jul 2007, 09:05
