I've been using the constant bitrate setting to make vcds/svcds but someone said you can get better results by using a variable bitrate. TMPEG has several modes including the 2 pass and the automatic VBR and I don't know which one to use. Can Someone advise me? Thanks.
Well, for lower bitrate encodes, and I want the best quality, I would recommend 2pass VBR.
If I have the luxury to encode at a higher bitrate, 7000 or so, and don't need to fit a long video on DVD, then I would use CBR. -
2-pass vbr is always going to be better...
It depends on how you set it up, though. It has a few more settings you have to take into account.Your miserable life is not worth the reversal of a Custer decision. -
I use CQ_VBR.
I read somewhere (in this forum perhaps? it was long ago) that TMPGEnc was built around it's "CQ" feature - ie its developers put a lot of time into tweaking the "CQ" mode specifically, over the other options. Is this true?
I DO know that I am very happy with my results with "CQ_VBR", and encoding times is cut in half (or more). -
The only problem with CQ_VBR is there is no accurate way of predicting file size. If file size is an issue, I use 2-Pass VBR. For full D1 (720 * 576) I set the Max to 9000, the ave to whatever the bitrate calc here tells me to, and the min to 2000. For half D1 (352 * 576) I set the Max to 5500, the ave to whatever the bitrate calc tells me to, and the min to 2000.
If in doubt, Google it.
ffmpeg rate control
By diprotic in forum Video ConversionReplies: 2Last Post: 15th Oct 2011, 23:35 -
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 13:53 -
Uploading H264 in MKV container to Youtube results in frame rate problem
By tokintmash in forum EditingReplies: 10Last Post: 4th Apr 2009, 03:36 -
Selectable Output Control - MPAA's new control tactic
By akrako1 in forum Latest Video NewsReplies: 2Last Post: 7th Aug 2008, 22:05 -
Having issues with Clone Mode in Catalyst Control Center...
By Jaxel in forum ComputerReplies: 1Last Post: 25th Feb 2008, 06:08
