Im using Ulead VideoStudio to capturen/editten etc.
To fit more on a DVD I captured at half resolution (352x576). After burning the DVD gives a small screen. What should I do to get full size at playback? And is that possible with Ulead?
I thought half-D1 was a DVD standard??? Are you saying it's not 100% compliable?
Just curious, because that's the first I've heard of that around here! -
It is dvd compliant and the reason its being played back at a smaller size is due to how its being encoded.
I capture and author all the time with 352x480 ntcs using Ulead and they all play full screen on tv.
Is there a internal setting on your dvd player???
If you are on pc, then check setting also -
Uhm...I tried the options 4:3, pan scan, 16:9 etc on DVD player but nothing helps. I have a Philips 640 standalone player.Originally Posted by snafu099
Oops ...now I have to say... I capture in Videostudio, but I make chapters in TMPGenc Author. And with TMPGenc I make the DVD files too. -
ohh.. aahh... had to change type from mpeg1 to mpeg2
Now its ok I think.
ty all
How to Maintain Correct Aspect Ratio in PotPlayer with Full Screen
By drstew12 in forum Software PlayingReplies: 1Last Post: 20th Dec 2011, 20:25 -
Question how to correct full screen mode too small
By jimdagys in forum ComputerReplies: 2Last Post: 12th Jul 2009, 21:34 -
Need help on how to author a DVD w/clips into a small section of the screen
By mbextreme in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 05:22 -
Window doing full and and small screen[maximizing auto] prob
By vipertongn in forum ComputerReplies: 1Last Post: 12th Sep 2007, 02:06 -
Lower video encoding tips for small 7 inch screen
By hauns in forum EditingReplies: 5Last Post: 9th May 2007, 14:54
