Ok, yeah, I am a n00b to the whole process of creating VCDs and SVCDs.
Ok, after admitting that, I will go ahead and explain the situation:
I have a couple of movies that are not divx and, as such, not in avi form. I honestly don't know the extension to the files, however, I do know that I burned them to a CD and made it an SVCD. I used Nero StartSmart and it converted it and burned it and it played perfectly in my Apex AD-1130W.
The bad part is that it took nearly 3 hours to convert and burn - but that's that I guess.
After this newfound success, I attempted to burn a divx movie using the same process. However, because of the size difference in the files, I had to split the file in half. I don't recall what program I used, but it didn't work correctly. The audio wasn't in the converted file.
So first of all: I'll ask if it's even possible to convert Divx to SVCD and have a working file, whether it uses two discs or not.
Second off: I'll explain my system specs.
Dell
Intel Pentium 4 w/HT - 1.8gHz
512 MB Ram
Intel Integrated AGP Video Card
Intel Integrated Sound Card
24x max CDRW
I'm using Memorex blank CDs 700MB/80 mins.
I did have success in converting it with DVD2SVCD and extracting the audio and I have attempted to convert the seperate audio and video files with TMPGEnc (Or something close to that, I'm not on my computer). However, I have two room-mates and one of them continues to close it out whenever she gets on it. So, because of that I didn't get it accomplished either.
So, if someone would be willing to take the time (again, more than likely) to explain to me the process in which to do it if it is possible and what programs I will need to do it. I apologize for asking someone to explain the process because I'm sure people have gone over it many times.
I just haven't had any luck with it and haven't been able to complete it. And all the guides here say different things and different programs.
I appreciate it if anyone takes the time to help this n00b.
Dincht
DVD2SVCD includes all the tools you need except for the encoder (it can use TMPGEnc which you said you might have) and the DivX codecs. Once you've configured it, DVD2SVCD will automatically do everything from extracting the audio, demuxing and remuxing the video and audio streams, authoring the SVCD.Originally Posted by Dincht
DVD2SVCD does take a few hours to complete all the steps
but you can restart the process from the step when your inconsiderate roomie terminates it.
Look to the left and search for DVD2SVCD guides that use TMPGEnc.
Good luck -
Well thank you - I appreciate it.
The other day I just decided to try to burn a movie to an SVCD without any knowledge of the process or programs. So it was kinda hard for me to get started or to even know what to look for.
As I said, I appreciate it. Thank you.
Jason
DIVX Movie Converting?
By RecoveryTTA in forum Newbie / General discussionsReplies: 0Last Post: 22nd Sep 2010, 21:22 -
converting Divx to QT?
By rotuts in forum MacReplies: 3Last Post: 17th Jul 2008, 17:28 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 24th Feb 2008, 00:35 -
Converting DivX to HD
By CFCproductions in forum Video ConversionReplies: 6Last Post: 18th Jan 2008, 15:11 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48
