Hi all.
Recently I bought a Sony home theatre system ( DAV –SB 100) and found out that this unit doesn’t play most of my VCDs ( so far was successful on one only that I bought here in America, Those VCDs from Europe I can see the first frame from the move and than I am getting blank black screen with audio only. Am I doing something wrong or simply it’s not compatible with VCDs. It’s strange that in documentation it says it plays VCDs. Some advice or hint would be very helpful and appreciated.
Hello,
You say the European vcds don't play???? Then its probably a pal issue. You need to convert it to ntsc to play on a North American dvd player.
Do a forum search for pal to ntsc and you'll get a ton of info. Also look it up in the guides under "how to" convert found in the green section on the left side of the screen
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
HOW TO CONNECT HOME THEATRE DAV DZ777 speakers to LCD and LAPTOP
By maaiz in forum Newbie / General discussionsReplies: 4Last Post: 17th Apr 2011, 23:38 -
Make new home cinema system Sony DAV-IS10 region free
By johli in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Mar 2010, 16:37 -
PS3 to Home Theatre System
By dhyane in forum Newbie / General discussionsReplies: 3Last Post: 28th May 2009, 09:51 -
Sony DAV-IS10 home theatre system
By joemarsh in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Jan 2009, 13:07 -
Home theatre system that can't play Divx
By mr-scarface in forum DVD & Blu-ray PlayersReplies: 10Last Post: 25th Jun 2008, 13:19
