ok what i have are mpeg1s on dvd. Im going to deplux them and then re-encode back to mpeg1 and put on dvd again.
I know for vcd bitrate is like 1100. What bitrate can mpeg1 that is going to be on a dvd media go up to?
Im wondering if i bump it up a little, will it make it more better playable? because at times this current dvd does pause for few seconds. Will quality improve as well??
Hi Solarflair,
I regularly encoded AVI files to MPEG1 files that comply with the VCD standard (i.e. about 1115kbs) using TMPGEnc, and then create a DVD based on these files (I can fit over 6 hours on a single DVD) using TMPG DVD Author. The resulting DVD invariably plays without any problem.
Hope that helps.
Tan -
im depluxing a dvd that sometimes pause for few seconds...
what can i do when i re-encode to prevent this from happening?
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54
