If I took a finalized -R disc in Video Mode recorded from my DVR-7000 Pioneer unit, and use the 520 to burn it to the HardDrive in realtime to make a new menu with thumbnails, then burn back to dvd-r on the 520, will I lose quality? Is there a re-encode in the process? Do I burn back in realtime also?
THANKS!
Richard
I can't tell for sure but in reading the description for this in the manual I believe there is decoding and re-encoding involved in the transfer from the DVD to the hard drive. There would not be if you used the disc back-up feature but that wouldn't let you change the menu.
To limit any loss in picture quality try to transfer at the same recorder settings as were used on the DVD. If you use High Speed Copy to burn the new DVD from the hard drive there won't be any re-encoding during that process.
You can use your computer to transfer the video from the DVD and create a new menu without any need for re-encoding. Plus you don't have to wait for real-time transfer. This presumes you have a computer and software to do video DVD creation.
Pioneer DVR-520 and DVR-560 functionality discussion
By jcool in forum DVD & Blu-ray RecordersReplies: 142Last Post: 17th Aug 2021, 19:45 -
Pioneer DVR 520-H does not recognize disc
By Steve_Rbts in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Sep 2010, 23:35 -
Recommendations for a HDD upgrade for the Pioneer 520-H
By Gypsy898 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 8th Mar 2010, 09:38 -
malata dvp-520
By jfethiere in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Jul 2009, 18:57 -
conversion from vhs video to Pioneer 520 DVR to Computer friendly format
By newguy23 in forum Newbie / General discussionsReplies: 4Last Post: 9th May 2008, 02:32
