Results 1 to 11 of 11
  1. Anyone ever used these Dupsonic DVD-R discs they've got for 23 cents when buying 500 at All Media Outlet. I'm leary of any brands I haven't tried, especially when they're that cheap.
    High-Quality, Japanese Made DVD-R 1X-4X 4.7GB Silver Shiny 25, 50, 100, 200, 500-Pack in Cake Box
    Sony-Quality!
    Made in Japan!
    Ultra-High Compatibility!
    Excellent Play-Back Capability!
    90-Day Money Back Guarantee!
    Write Speed: 1X-4X Certified
    Storage Capacity : 4.7GB
    Disc Diameter : 12 cm
    Conform to DVD Specifications for Recordable Disc Ver 1.9 & Ver 2.0 (DVD-R)
    High quality organic dye recording layer materials improve short wavelength recording characteristics for reliable recording and playback.
    Precise substrate molding and improved disc bonding technologies effectively control tilt of the disc for outstanding reliability and durability
    Compatible format for DVD-ROM master disc production and a high capacity for archive storage.
  2. Member deejay.2001's Avatar
    Dec 2002
    i am pretty sure they are junk
    something like cmc magnetics dye....
    you better buy some TY for 0.23 cents.....if you can find...of course
  3. Member 888888's Avatar
    Jan 2004
    Turdistan
    TY for 23 ents? Whatcha talkin bout!?
  4. Member deejay.2001's Avatar
    Dec 2002
    i said if you can find...
    canada
    If they are really made in japan then buy them.
  6. Member 888888's Avatar
    Jan 2004
    Turdistan
    I'd buy them for .33 cents each too if I could find 'em for that price. I'm guessing you are referring to branded spindles after rebate like Fuji.
  7. It's hard to imagine they're too bad considering they are offering a 90 day money back guarantee. You'd have to be a complete idiot to sell garbage and then offer a 90 day guarantee. I could be wrong. Anyone get these yet?
  8. Originally Posted by 888888
    As stated in other posts, you can get 100 TYs for $20, that comes out to $0.20/disc. Use Circuit City B1G1 coupon at Best Buy on their Fuji 50-pack spindles (buy the Made In Japan ones)
  9. I've now burned 20 of the 8x colored DVD's from allmediaoutlet.com - they seem to be okay - NO burn errors and they all passed the verify written data test in Nero. They have also copied just fine either via nero image or DVDdecrypter.
    they also had this ID tag
    Media code/Manufacturer ID: TYG02
    They are NOT made by Taiyo Yuden but they seem good to me :P
    Sing while you may.........
  10. Video Restorer lordsmurf's Avatar
    Fakes. Avoid.
    May 2004
    WA state USA
    u can buy 50 packs or this crappy media for 15.99 at pcclub.com
    the -R's might be fine, but i know the +r's dont work, and i have 3 differnt burnes, one burnt but wont play, and other 2 couldnt even read the crap media
    dont waste ur money on these
